1g hks cams 272 and timing,spark plugs ?
EXTREMEPT
63
Dec 9, 2004
PENSACOLA, Florida
i just installed hks cams into the car today and it is set a stock timing 5*btdc...should i advance it or retard it any or leave it the factory setting?also what about the spark plugs 1 step or 2 steps colder ? this is the mods i have on the car if that helps..
1g talon awd turbo
550cc inj's
255 walbro
fpr
hks 272 cams(stock cam gears)
3" 02 eliminator dp,
no cat
3" cb exhaust
big 16 g evo ported/clipped (boost @ 20psi)
evo ported mani
greddy type rs bov
3" gm maf and dsm translator
I was never able to run that much base timing with e16G at 20psi.
Right now, I have mine set at 1 BTDC
yes i have it set at base timing and running the ngk bpr7's should i run the ngk bpr8's
I'm running 50 trim with Crower stage II right now.
I don't know but my car doesn't seem to like alot of timing.
when i installed the cams today i had to take the cas off of coarse and when i put it back on it was at about 3-4 btdc and the idle was low and throttle response was slow...so i put it back to 5btdc seem to help a little...should i try to set it a little higher like 7 or 8btdc ? i know i ll see a lil more power on the bottom end but how much will i lose on the top by advancing it to 7 or 8 btdc ?
Did you reset the ECU? Always reset the ECU after the cam install. THe idle usually gets better once ECU relearn the new setup.
doh, i forgot to reset it...was tired (durrhhh) will reset it in the morning..thanks i totally would have forgot to do that...
