What Will Help My Fuel Cut?? Detailed...
project_tsi
Honorary DSM Wiseman
DSM Wiseman
2,699
118
Sep 4, 2004
Eau Claire, Michigan
Hey guys, ive got a 92 tsi awd w/ the following mods, and on cold days i always seem to be hitting fuel cut around 4K RPM's. ive got 550's but i havent had the time to install them yet, and an OLD style afc controller w/ the 5 knobs. would adding the 550's, and a new style s-afcII help out w/ the fuel cut, or should i just go w/ the 550's, and a new ecu chip from dsmchips.com thanks guys,
Here is the current mod list.
Rebuilt 6 bolt
2g pistons
2g lifters
mild ported head(gasket matched and polished)
ported intake manifold
2g ported exhaust manifold
ported o2 housing
Buschur ported and clipped big 16g
tial 38mm external wastegate mounted on manifold
3in downpipe
3in testpipe
3in exhaust
brode upper ic pipe
turbo xs rfl blow off valve
RRE spearco 221 front mount intercooler
Buschur turbo outlet
big throttle body elbow
maf 2.1 translator
3in GM mas
S-AFC
rewired denso 190lph fuel pump
RC 550cc injectors(not installed)
k&n filter on custom 3in intake pipe
hallman MBC
autometer boost and air fuel in a gauge pod on pillar
Must you really ask? Doesn't the MAF Translator have injector compesation? Put the 550's in and compensate for them.
I run a SAFC I Blue Screen and FIC 650's and I have NEVER EVER had fuel cut.
gsxtacy
check for boost leaks and if you dont have any then install the 550 and compensate with the MAFt
the cpu has already counted the leaking air..On my car I have the maft in a blow through setup so all the air before the mas wont matter, right???
you could still have a boost leak in the throttle body, at the TB gaskets, in the vacaum system, etc... since you have a maft you dont need to pressurize it from the turbo on just hook the leak tester up at the maf. that way you only check what you need too
