tlip93tsi
- Sep 9, 2002
I am about to install a set of webcams "street" cams, and crower springs/retainers and i was wondering what kind of supporting mods I would need to go with. BTW, my engine is stock.
Hey guess what I thought about it your WRONG! Take a look here this is the before and after with the web cam street grind on the RRE website. Notice the power loss all the way up to about 4300 rpms? There is no appreciable gain in power until about 6200 rpms. The 14b would have lost steam a long time before that and you wouldnt make any power that high in the rpm band. So for this kids entire power band he would have LOST power. Not to mention the fact that he would have to deal with all of the idle issues that would need to be resolved with a safc that he doesnt have. The real reason to switch to cams is so that you dont lose as much power AFTER 6k this is only required if you have a turbo that can make power well past that point.Originally posted by Big Woo
Not true, If you think about it. The WEBCAMS street grind "will" provide more lift and duration than the stock cams, thus allowing more time for the intake charge to fill the cylinder. This will have a bigger effect when larger turbos are used, but they will make more power than the stock cams even with the stock turbo.
Well gee if you want to be that picky I guess we will never know for use until we hit HIS car with a before and dyno graph. Look at the graph again sparky this is a 16g powered car a 14b will more than likely make less power most of the way through the powerband. Aftermarket cams will only show a power INCREASE after certain RPM point up until that point they will more than likely LOSE horsepower. This will be even more accurate in a near stock car.Originally posted by Big Woo
Well without seeing a dyno plot with the Web cams a stock engine,and a 14b we will not know for sure. The Web cams will still provide a power increase over the stock cams.
It is comprehend WHAT I said and YOURE a wiseman Good job buddyOriginally posted by Big Woo
but you did not comprehend want I said, and your a wiseman
I dont think any cam worth keeping will make more power on a stock car. Even a pair of HKS 264s would more than likely lose power through most of the band over stock.Originally posted by Big Woo
Do you think that no other camshafts will make more power than the stock ones in a stock engine?
The problem with this is that the 16g also has trouble air flow wise in a stock engine. The 14b would just start losing power a lot earlier. Yes cam timing CAN have a SMALL effect on hp but from what I have seen from a lot of other DSM guys dyno charts cam timing changes produce minimal gains at best. You would also have to factor in the additional $600+ for cam gears.Originally posted by Big Woo
I do understand that the powerband will move up the rpm range as camshaft duration increases. I also looked at the graph and it shows a small increase in power in the upper rpm ranges with a 16g. There are however other factors such as since the 14b will have trouble keeping up "air flow wise" having a larger intake camshaft may allow for better cyilider filling than the stock cams in the upper rpm ranges with a 14b turbo. Also altering the cam timing cam cause changes in the effictive powerband. Like advancing the intake cam will tend to make engine respond earlier in the rpm range, while giving up a little bit at the top. It will also decrease the overlap period, and close the intake valve sooner thus building a little more cylinder pressure than if the cam was installed straight up. That could also be coupled with retarding the exhaust cam, and further reducing the overlap period.
I cant believe you are still arguing. But hey whatever you just wont accept the truth thats fine. Dont just look at the RRE graph do some research on the HP gains that people gain on cams and at what point they make there power. I am DONE with this thread. Im ready to let it die.Originally posted by Big Woo
Since we don't know where the cams were set, and differnt dyno runs at differnt camshaft posistions, we do not know if this is as good as it gets for a set of web cams and a 16g. We are getting way beyond the original question. The answer is it depends on who you ask.
