worrgrover
- Jan 27, 2005
Pemberton,
New Jersey
i know this might seem lame to you guys but i was hoping for an answer on if you think i might be able to hit 500hp w/ my setup, the car is going in the shop next week and i was wondering if i can expect 500hp at the wheels. im putting out ALOT of money so i would hope i will get that as a result. also i was wondering what max psi the bottom end is rated to w/ ross 8.5:1 pistons, and eagle rods, stock crank. but my setup is as follows.. ::
272 intake 272 exhaust hks cams, td06 ported 20g turbo, fidanza cam gears, slowboy racing tubular exhaust manifold, external tial 38mm wastegate, apexi avc-r electronic boost controller, s-afc II, ross 8.5:1 pistons (20 over), eagle rods, greddy type s bov, gm 3.5'' mass air flow, gm translator, charged air fuel pressure reg, 650cc injectors, dsm link, arp headstuds, mitsu multilayer headgasket, act 2600 clutch, act streetlight flywheel, custom made intake manifold w/ 3.5'' runners. thats pretty much all of it, other then the porting and polishing of head. im putting out about $9500.
but basically my questions are, would i b able to push 30psi(w/ a better bov that is) and at 30psi do u think i might reach 500hp? or more?
but anyways you probably could be good for it but dont take anyones word for it until you get to a dyno. and jus between me and u i think it is agianst the sites rules to post in forums asking for hp estimations.
. but i am just dreaming and heaviliy medicated at the moment cuz of my back.. yea thanks for responding and making me feel special tho =D
