governer question
iam_canadian22
Jan 11, 2005
Val Gagné,
i just bought my 1990 eagle talon tsi awd this summer, the timing belt blew on me before i had the chance to change it. since i was doing about 160 kmh when it happed i knew there was some bad damage so just bought anouther motor instead of fixing it. the problem is the motor i bought is governed, i was wondering if it is possible to remove it some how? thanks for anyhelp
iam_canadian22 said:
im not too familiar with these cars yet, can anyone tell me where the ecu is located? thanks
The engine in the car is not "governed"...any type of speed control takes place in the ecu, which is located behind and directly below your stereo....... :dsm:
I wasnt aware of any governor other than the fuel cut setting. Specially on a 1g :confused: Why are you looking for this? What problem are you having that would make you think it was a governor causing it?
well the last motor i had i would easily hit 180+km/h and this one always cuts out at 140km/h, any ideas?
