dewdew
- 93
- 1
- Jun 13, 2002
Puyallup,
Washington
I have boost creep, it sucks. My boost was fine settling around 12 PSI pushing as hard as it could. Then I installed a 3" Turbo-back Apex-i N1 exhaust on my 1992 GSX. The boost guage will show numbers slowly rising past 12 PSI, sometimes reaching around 20 PSI. The only other mods I have are a M.B.C. and Intake. How do I correct this...will a O2 sensor housing upgrade and a ported manifold help? You gotta help me out guys.
Ported the WG exit area. Tht made the biggest difference. Boost down to 17 psi. Ported the flapper hole, boost down to 15 psi. Opened up the exit area even more, down to 14 psi. On stock flapper. O2 housing was lightly ported, and still got 14 psi. there isnt a whole lot you can do for creep with it, but it wont hurt either. IMO, 2g hosuing is even WORSE for creep, contrary to popular belief. The way they put the O2 sensor right in front of where the WG runner meets the main passage is just retarded
