TMO Clutch Wire with diode
ICE_T
199
Nov 10, 2003
Laval,
I put my new tmo stage 3 on my ECU eprom bord with a socket.
before install my clutch wire,. I cut the pin #104 from the ECU connector and leave it free,. to see if the chip work. Every thing work perfectlty.
I can set 4000, 4500, 5000, 5500 and 6000 rpm launch. and my rev limiter was set at 5500rpm.
So,.after I see everything work,., I decide to connect the clutch wire with a 1kv diode.
I follow this link:
http://co.dsm.org/tech/TMO-clutchwire.jpg
NOW,. I can't select a different launch RPM. It's set to 4500,. I follow the step from TMO website,. engine OFF,. key ON,. press pedal clutch, etc...
but still at 4500 launching RPM.
I dunno why?? Maybe a bad connection ??, I put my diode on the GREEN wire from the clutch connector.
thx,,. for the suggestion.
I didn't follow the link to the directions, but are you sure you put the diode in the right way? I'm not sure of your electronics background, but diodes are like checkvalves--they only let signals flow one way. Check to make sure you didn't install it backwards.
thx for your reply,.. no the diode I put it in the other way and it's work perfectly.
I just see that I don't do the steps well. I forgot to press the throttle pedal when I press the clutch in.
So everything is OK.
close topics.
  • For sale 1g 90 Oil Cooler
    • kyler021
