Engine Swap
rhogaboom
May 6, 2002
I Have just set a complete used (30,000 miles) turbo engine into a (Oct. 1991) non-turbo manual Trans Plymouth Laser. Now I am faced with getting every thing hooked up like the vacuum control lines and the Wiring. I Knew that while the 2 engines where for the most part the same there are many thing that are not the same. (Other than the turbo and that this engine was bolted to auto Trans if that makes a differnce)
I would like to set this car up to pass CA smog check. What I need for now is good wire & vacuum line diagrams. I have never work on a DSM car before but do have the skills needed to make this work. If I can get the info needed it will save me the time it would take to design my own modifications.
Engine # stamped on the block
4G63
NA561
# on turbo
S B100650
49177-01900
TD04
Parts I know I need!
Exhaust Downpipe (for stock O2 sensor housing & CAT. Converter)
Air Filter, K & N ?
Air Filter to Turbo Intake Pipe
Intercooler (side mount)
Boost Control
Lower & upper intercooler pipe
Blow Off Valve (BOV)
Thanks For any Help!
