bullseye housing B16G or 20G for pump?
Shadowfax
152
Jul 27, 2004
Stillwater, Oklahoma
Okay all, tried searching, got some answers, but nothing too concrete...
my FWD 1st gen- want 115ish traps- but will be 95% pump gas only - it's my daily driver. I won't be at the track often, I won't be running slicks and stiff suspension- I just want top end from hell :D
So if I was only on pump, wanting to make sure I can stay head to head with say, a Z06 then what would my best choice for turbo be?
Big or EVO 16G with a 7cm2 Bullseye housing
OR
20G probably TD05 back end
I'll have the fuel and airflow taken care of, 3" Downpipe and catback, 2nd gen ported manifold, wastegate dump (likely but not 100% if not then at least tubular at 2.5"), FMIC, poly roll mounts, equal length halfshafts... possibly LSD if I must ;)
anyway- the 20G has a greater top end I know- looking at the fastest DSM times, I can tell that the 20G is easier into the 120+ range- but that doesn't 100% mean it's better at PUMP GAS to 115MPH.
So... again I ask-
Bullseye B16G
or
20G TD05
For pump gas I would say the 20g, you would have to run alot of boost on the 16g and would be on the ragged edge. The 20g wouldn't have to work as hard and could do it with less boost.
Id also say the 20g. Will hit your goals a bit easier, the little bit of extra lag will more than likely help you with your FWD, and plz for the love of god get that LSD its a must have for any FWD that wants to go fast.
