DSMatMSU
- 128
- Nov 18, 2004
Starkville,
Mississippi
recently my car has been running very lean under heavy throttle and WOT... Im thinking i might have a bad FPR, since ive tried just about everything else, including two sets of injectors., new o2 sensor (it cycles fine at low throttle, per the logger), and a new fuel filter
I found out I had an automatic motor in my manual, thus having smaller injectors... i picked up some used 450s, and i still have the same problem...
all the junkyards around here have 1.8L or 2.0 n/t.... i read a few threads about raising the FPR with the N/T regulator.... so im considering giving one of these FPR a try... i have a EVO 3 16g turbo... i dont have an AFC or injectors YET (note only running 13 psi at the moment)
but i do have the walbro 190 (re-wired)
i have a little fuel pressure gauge i was going to install.... can i just put it in-line btw the fuel filter and the rail?? with a NTP T-fitting... basicly just for diagnosis purposes at the time...
which one should i pick up the 1.8 or the 2.0???
is the fuel rail for an automatic different??
is the FPR for an automatic different??
or could something else be causing a loss of fuel pressure?? im going to pull the pump to see whats going on down there as well...
but I can just read and it will pick up CELs... the only other test that works is the injector test, where you can turn each one off.... none of the others do anything....
