spyder 2.4 dohc swap compression ?????
slopefunk
66
Jul 17, 2004
jacksonville, Arkansas
Hey thinking about this swap. Wanted to know what the cc's is for the sohc I think the dohc is 46. My question is when I go to swap this head is this going to change the compression on my spyder. Im thinking about doing this swap cuz I have everything already laying around from my old motor out of my tsi.
thanx
Are you keeping the car N/A? As in are you wanting the car to work like a '94 Galant GS?
If you are wanting to turbo the car you are undoubtedly going to need new pistons and rods, will have to plug up some holes in the block. Everything that's described in the seven bolt 2.4 thread.
http://www.dsmtuners.com/forums/showthread.php?t=49472
not going to turbo just asking what compression will I end up with when all is said and done not going to turbo it
Hi,
I have the 4G64 block with stock pistons. Someone told me that they have 11:1 compression. If this might help.
Sven
Not hardly.
The '99 Spyder GS had 9.5:1 compression. 9.0 for Cali cars. I'm not sure how turbo cams and ECU will like an engine without a turbo. You may be better off finding a head or cams and a ECU from a '94 Galant GS.
