Removing cam gears
ambcamry
36
Jul 12, 2004
Tehachapi, California
what size wrench do i need to hold the cam in place while taking off the cam nut. i dont have a wrench big enough so i have to get one.
Thats for the cam gear bolt .
I need the size of wrench to hold the cam to remove that bolt
1 1/8th" I believe. I had to use an adjustable wrench with nearly a 2ft breaker bar and the same length bar on the breaker bar for the bolt.
Be prepared to exert some physical force to get it off :D
-Dallas J
I used an impact gun :thumb: Just make sure the cam is secure and held in place..you don't want the impact gun to spin the cam and end up with some bent valves. :D
