TD05HTalon
- 128
- May 2, 2003
Gainesville,
I'm so close to getting my 6 bolt running but it just won't start.
Did the rewire for the CAS using the stock 7 bolt connectors. so those connections are all good.
I installed the CAS when the crank marker pointed at TDC and the cam gears were lined up. I made sure the CAS was lined up with both notches before putting it on too.
The motor cranks over so the starter works.
I get fuel since i can smell it and if i disconnect the fuel line from the rail fuel spills out. Also my fuel pump is running because i can hear it.
The ignition coil is good and so are my wires - i used a spark tester and all 4 wires carried a nice healthy spark from each coil plug.
Any thoughts? I would really like to get my beast on the road!
Edit - moderators - sorry i didn't put this in problem diagnosis where it belongs.
