dylan98318
- Jan 5, 2004
ocean city,
New Jersey
i want to build a 10 second talon but i need help, i dont want it to do anything less than 10s. i have a 1990 6 bolt block with arp studs in it. i have je pistons which are 8.5:1 compression 0.020 over bore, and i also have eagle rods. there is a shop in my area that can build the block and one of the guys were telling me that he can knife edge the crank and also take pounds off of it which would make it much lighter. i have seen him do it to another dsm crank shaft and the weight difference of the cut crank to the stock crank is way different. the cut crank was about 5 pounds lighter and im thinking about doing that, that extra cutting of the crank would be like $800 alone just to do that and i would balance the whole engine with the flywheel pistons and rods. i want to know what performance i would get with a much lighter crank or would it not make a difference. anyway, thats all i want to do to the bottom end.
on the head, i want to do a 5 angle head job with 1mm over sized valves, i want hks cams, 272 degrees intake cam, and 272degrees exhaust cam. im not sure what valve springs and retainers i want to go with yet but i have my eye on ferrea.
i have a green turbo which i think is a 50 trim turbo and i dont really wanna change to another turbo. i have a honed out 2nd gen exhaust manifold and im thinking of getting one of those chrome looking tubular exhaust manifold. i have three inch exhaust system which is apexi. i have 680 injectors hacked 2nd gen mas. walbro fuel pump, act 2600 clutch, rebuilt tranny 2 gear syncro yadda, yadda, yadda. i think i want to get a aem fuel management controller computer, or a dsm link which would be way cheaper.
i would like someone to help me out and tell me what i should get or what i should do and what i should not do. i dont want any mistakes so thats why im on here asking for help.
so again- i have in my car a stock dsm engine, bolt ons are green turbo, tial wastegate 40mm, honed 2nd gen exhaust mann, 3 inch exhaust, 2nd gen mas, rebuilt tranny 2 dog dif, clutch act2600, super afc 2, eprom computer stage three chip, walbro fuel pump, 680 injectors.
i have seperate a 6 bolt block with arp studs.
please help me if you have any thoughts on how i can make my 1990 eagle talon do 10 seconds.
1990 eclipse running in the 10s. gosh, whoda thunk it. I know he has a lot of money in it, but hes built and tuned it all himself.
If 11's aren't enough for you, then you probably haven't ran an 11 yet.
