Can someone tell me the right head gasket!
rcarrier
87
May 4, 2003
Bluff City, Tennessee
I am in the process of building a new engine, i was wondering what is the best head gasket to get, gonna be running 25+ boost,9-1 compression,full balanced motor!
Thks guys!
Is that going to be a street or track car? With what I consider to be high compression and 25+ PSI that sounds like an o-ring to me. mark
look into the cometic metal head gaskets. They come in diffrent thickneses so you can chose the right one for your compression ratio. The mitsubishi metal head gasket is also a good choise but it will lower the compression slightly. Use ARP head studs also torque them final to 80 FT lbs.
