RRE Boost Controller Install Help
SD GST
73
Jun 12, 2002
Before anyone says use the search, I did and I can't find anything for the RRE Manual Boost Controller.
Anyways, from what I did find on the search, I have tried installing the controller 3 different ways and no matter how I install it, I can't get more then 10lbs of boost.
The instructions that RRE sent were all blacked out, and I could read anything.. I asked for new instructions and never got it. They usually have good service, but I guess I slipped through the cracks..
Anyways,
I installed it where the "Y" connects to the BOV and the Intake manifold, and the other hose connects to the waste gate.
I have connected it by taking off the Y and connecting from the turbo to the wastegate with the controller in between.
I have connected it where the Y connects to the Wastegate and Turbo and the second hose connects to the intake, like the stock BCS...
I am supposed to go to the track tomorrow, and I would like to be able to boost 15lbs, instead of the 12 / 13 I am now..
Anyone with an RRE Boost Controller, Please help...
I believe the first way you have set it up is the way my MBC was set up.
"T'd" to the bov line and the other side to the wastegate of the turbo.
did you cap off all the unused lines on the stock BCS and intake pipe.
I didn't cap off the BCS.. I capped off the Turbo outlet.. Maybe that is the problem.. Also, I noticed on the "T" of the MBC, there is 1 side that has a brass fitting inside the "T". Do you happen to know which side the fitting is supposed to be on.. The Intake manifold side, or the BOV side?
