intercooler piping?
KOMPLICATED
Aug 30, 2002
Just a quick question. Should I get the upper and lower intercooler piping now? or should i wait until i get my FMIC kit? and if I did decide to get the piping now, would it fit (i.e. be long enough to reach) the FMIC?
if your going to get your FMIC kit REAL soon, just wait till you get that. depending on what FMIC you are getting will depend on if you can use the aftermarket upper ic pipes that route to the STOCK SMIC. If you get aftermarket upper ic pipes now (throttle body to smic), if you want to be able to use those still, then you have to get an FMIC kit that routes back to the stock SMIC location, which I think is the Greddy ones. I don't know which other ones. If you get an FMIC kit with shorter piping, then the ones which go to the stock SMIC is useless. Just from what i've read, hope that helps.
