AgpT25/28
Rob
707
Aug 26, 2002
What kind of hp should i expect from this turbo with out boosting it just at 15psi < cant boost it yet still got the stock fuel pump and injectors>
with down pipe, greedy blow off valve, and injen intake ??? any numbers ?? will i feel the difference when i just slap it on?? I will do the porting when i put the turbo on :thumb:
hehehehe thanks not the answer i was looking for was looking to see if someone had a fpT28 <AgpT25/28>and about the same mods and had some numbers or hp numbers =0)
also i am ordering a O2 dump for my car can i use this with the agpT28 ?? i think the agp has an internal waist gate someone was saying you cant ??
Just by slapping it on you will feel a difference. Mine was a big difference. You have to get feul pump if you want to run more boost but the stock injectors are good up to 17-18psi. I'm not saying you don't need the injectors but if your not turning up the boost real high then you won't need them just yet.
im not going to be able to take full advantage the damm stock clutch is sliping at hard launches =0( LOL .......but im going to be geting the Act 2600 clutch, everone says these are so good any bad info on these clutchs ? beside paying almost 400.00 for them =0)
    • eclipsemf
