92tsifwd
- 572
- 1
- Feb 1, 2004
Hastings,
Nebraska
I installed a safc2 and the car won't idle now. It starts and the CEL comes on then I hear a click from the ecu and it dies I followed the exact wiring diagram and it apears to work but it will not idle. I am unshure of the nessessary settings to make it work corectly Someone said I need to switch air flow type to Karman Vortex but I see no option that sais that. I am unshure of what dec. air is for also I put it on 4 cyl and the arrow to the the upper right. I put the Net at 30% low and 80% high and the settings are 0% on all. It came with no instructions. I tapped the knock purple wire to pin 9 and ran a ground from purple wire to chasis ground. Any info about this is greatly appriciated!
