STARION
- 193
- May 30, 2002
Nova,
Bad wording, but anyways, what I am wondering is are the balance shafts ineffective the lower the RPM? I am pretty sure that they ought to cancel vibration at any RPM. I ask because I just finished my engine swap and the Motor @ 500 RPM (idle), (yeah I know, it should be 750) shakes the car like crazy. Say that I open the door for example, the door will be shaking (very visible). Then I rev, and it seems to go away, The car is setting a check engine light which I will get to, but I was wondering if anyone knows about the balance shafts first. I just did the belts and followed the Vfaq, but think it could have been wrong here:
"NOTE that there is an easier way to do this. Simply rotate the mark on the oil pump sprocket until it is pointing straight up, and let it go. If the sprocket rotates towards (counterclockwise) the timing mark on the engine, the oil pump sprocket is aligned correctly. If it rotates away (clockwise) from the mark, spin the sprocket a full turn and test again, and it should properly rotate towards the mark now. Now line the mark on the sprocket back up with the mark on the engine. This avoids having to remove the rear access bolt entirely. "
I followed this exactly and set it according to them and all other timing marks were dead on, but is this accurate? I ask because I am positive that this could have been the only error, even though it did in fact rotate towards the mark.
help.
thanks,
Kent
help.
thanks,
Kent
