oem stock injectors and SAFC
With an aftermarket fuel pressure regulator you can squeeze quite a bit out of them .
The fact is that the you are going to be very limited as to the amount of boost you can push . The injectors can only stay open so long before they hit 100 percent duty cycle and then you will notice diminished performance . With an after market fueIpressure regulator you can turn up the fuel pressure 5 more pounds and flow more fuel with less of a duty cycle . This will allow you to not max out the injectors and keep you from running lean. Yo uhave already upgraded the fuel pump so it is time for a regulator.
