BigBoosh3712
- 35
- Oct 13, 2003
Clemson and Simpsonville,
Hey guys, My room mate is buying a SC61 turbo and he was asking me something about the different turbine wheels they come in and it got me thinking and I was confused. So maybe someone can help clear the confusion.
I don't know if you are familiar with Precision turbos but they make an SC 61 turbo. They make 3 different types, in which all of them use the same compressor wheel. The only difference in them is their turbine wheel style and trim (they all have the same A/R). The first one uses a T350 turbine wheel and is a 52 trim, the second one uses a T04 (which flows more than the T350) wheel and is a 69 trim. The third one is a T04 wheel as well but it is a 76 trim.
They all are rated for the same power...so my questions are this....First, why would you get a larger turbine wheel (hence, causing more lag) if either way you'll get the same power. And second..why would getting a larger trim turbine wheel help at all, if any. Still putting into consideration that the 69 trim and 76 trim T04 turbine wheel net the same power. Thanks for the help.
On smaller displacement engines (such as the 2.0L Mitsu), it is highly recommended that you use the 52mm (not trim, it's actually a 76 trim) T-350 wheel. The only time one should remotely even possibly in a long shot use the 69 wheel in a Mitsu would be a drag only car with nitrous (at least that's my opinion). I would almost never use the 76 P-trim wheel on a Mitsu, the engine doesn't have enough velocity to spool it quickly enough for these purposes. The bigger exhaust wheels will flow a little more, but the SCM6152E will support at least 630 Peak flywheel horse. The SCM6169 are rated around 650 peak flywheel horse and the SCM6176 is rated at 680 peak flywheel horse just for comparison sake. If you want a little more, the S-cover (4" in/2.5" out) will add roughly 10 more horse.
.Mark
