I need a rebuild kit!!
slow_talon
144
Jul 8, 2004
Brownsville, Texas
where can i find a rebuild kit for my 14b? the reason i'm asking is because my turbo is leaking some oil from in between the compressor housing and the exhaust housing so i want to do a rebuild? :cry:
How bad is the shaftplay? Be sure to scribe a line on the nut, wheel, and shaft so you can line it back up. This way it will not go out of balance.
there is no shaft play on the turbo, but it is leaking some oil that's why i want to rebuild it. :talon:
Is it leaking out the compressor or exhaust housing? You have either a blown turbine or compressor piston ring inside the turbo, or some solidified o-rings inside the turbo (running to lean melts the orings and solidifies them, then they don't seal). It may also just be lot of coked oil inside the turbo hindering its ability to drain propely. When this happens, oil will leak out of the pistonrings, no mater how good they are.
Piston rings are about $2.50 from your local turbo rebuild shop...there is usually one around. O-rings are a littlemore. It does not sound like you NEED a rebuild kit, though I would recommend it.
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
