fuel cutoff
tsi talon
Sep 10, 2002
a friend of mine said if i hack into the maf sensor that i would eliminate fuel cutoff. is this true and if it is what wires do i splice into?
You take the lower honeycomb out of the MAS and remove the silencer and there is no wire splicing required. Go to www.vfaq.com and check out how it's done. It's simple, like this question ;)
I don't think you will be able to totally get rid of fuel cut with just these free mods, but it will definately help and delay the inevitable.
Hack the mas, or better yet, hack and splice in a 2G mas. Add some big injectors, and lean them out with an SAFC. You wont hit cut for alot of boost. I run 20psi on the street. No hint of cut. I have had it up to 24psi, still absolutely no cut. Your results may differ though.
I run a hacked 1g Mas with the lower section completely removed, not just the honeycomb but everything. I also run a custom 3" intake. I have things set at 18psi and never hit cut and it used to creep up to 20-22psi before I did my portwok and still no cut. Each car can differ however so try it and see what happens.
    • eclipsemf
