gritsak
- 442
- Dec 31, 2002
went to retorque my headstuds and decided to pull the plugs to see whats goin on...keep in mind the plugs are only about 20 miles old......well #2 cylinder plug was completely black and wet, while the rest of the plugs looked pretty normal.
first thing that comes to mind is a stuck/bad injector, but i just had my injectors cleaned and checked right before my buildup (~300 miles ago, and they are denso 720's btw) so unless something has happened by then they should be fine
plug wires are also brand new...
so last thing that comes to mind is the coil pack...unless someone has any other ideas i guess i should try and borrow or find a used coil pack and see if that helps.
am i on the right track here, or any other suggestions?
edit: i guess i could also switch around #2 cylinder injector with another cylinders and see if the problem changes
