tartay
- Sep 14, 2002
Livermore,
ok i am just wondering...what does clipped mean? i see turbos for sale that are "ported and clipped" so what does clipped refer to? thnx guys
Originally posted by HighPsi91
When a wheel is clipped it refers to the process of grinding a little bit of the edge of the turbine wheel away. The part that is clipped off is the edge of the blades that you see when looking into the exit end of the turbine wheel.
The higher degree of clip the more blade is cut away... which will increase flow through the wheel but at the expensive of a little boost response.
