GSX4LIFE
- 709
- 30
- Aug 17, 2002
Anybody considering an L2R, or any Hybrid with a TO4E compressor housing on a 2G? If you are, you may or may not already know that with a stock mannifold, YOU DONT HAVE THE ROOM! Not unless your willing to crush your the big water pipe to the point that barely any water can flow. Well, this is something I was not confortable with. So I did something about it. I used a spacer plate that I hed from my previous setup. The plate and longer studs can be purchased from www.hahnracecraft.com The spacer plate between the head and manni is part # HTZ-7100. It costs $28.90. You will also need longer studs for the head.(Dont worry its a good idea to replace these when you do a turbo swap anyway) they are part # HTZ-6135, and cost $1.50ea. You will need 7 studs, so $10.50 for those. Total cost: $39.40.
With this plate any Hybrid with a TO4E comp. housing will fit perfectly! You wont have to touch the water pipe at all. Dont forget to an extra gasket from mitsu(You can reuse your old one, but you will also need one more). And No, you wont have any leaking issues. It wont leak, PERIOD! The ans will most likely have to go(I got away with only tossing the drivers side, because the L2R's wastgate actuator is on the turbine side), but this happens anyway with alot of turbos.
Here is the pic again.
