What to get next...
FlaToUt-GST
116
Jun 14, 2002
Ok, my big 16g ships out tommorow and i currently have ~$250 to spend. My current mods are in sig. I was thinking of getting a dp from either AHP or RRE,or a fuel pump, or logger software and link (i have an m100), i just cant decide. I'm leaning towards an AHP dp since it's pretty cheap. What do you guys think i should go for next? Thanks in advance!
Dowpipe,then fuel pump. Logger is nice to have but you need other things first
yea i think im goin with the dp, then i'll probably have to port some stuff tho. A friend of mine has a nice grinder, and if i can get the right bit i might try porting myself. Any reccomendations on a dp? AHP and RRE good ideas? Cant get the Apex one cuz i have to be able to swap a cat in. Thanks!
Id go with a fuel pump then dp afterwards. With no fuel mods at all Id want to at leist have a fuel pump with a 16g!! Maybe its just me, but without a logger to know and 16psi with no pump or even a rewire is something that I wouldnt do...
im probably gonna run more along the lines of 13 psi right away, which is still better than any psi on a t-25. 15 psi after dp and pump.
