truwarrior
- 1,422
- 6
- Dec 19, 2002
My logs acorrding to DSMLINK indicate I'm pushing around a max of 20lb/min. I have an unhacked MAF. Anyone else pushing more? My exhaust is pretty well freed up...
truwarrior said:My logs acorrding to DSMLINK indicate I'm pushing around a max of 20lb/min. I have an unhacked MAF. Anyone else pushing more? My exhaust is pretty well freed up...
philipkrotch said:do you mean your pushin 20lbs...as in psi??? if so, id say that turbo has been maxed out about 6 psi ago. maybe im not understanding you correctly though.
Violater101 said:No, he is talking about airflow which is lbs/min....there is also another way its measured, but I forget the exact term right now.
..didnt want his turbo to have a nucleic meltdown or anything..
Syndicate13 said:It is also referred to as CFM, or cubic feet per minute. Also, just curious, why do you have DSMlink and only a T25? I wouldn't be worried about airflow on that turbo, I'd be more interested in velocity, the speed at which it hit the trash can.
nanokpsi said:CFM is a measure of volume. Lb/min is a neasure of mass. It can also be configerd as g/sec or g/rev.
As far as seeing 20 lb/min. I think most people see 20-24 lb/min before they get rid of it. Are you any any kind of altitude as that will have an adverse effect on airflow.
Syndicate13 said:I why do you have DSMlink and only a T25? I
98spydert said:Probably the same reason I have 650s installed with my T-25 and the E316G is sitting on the floor; he's planning ahead. Smartest way to go imho
RuBiCaNT5X said:Word on that... DSMLink is by far the best mod for the DSM...
Syndicate13 said:If you ever see a compressor wheel rated it's rated either at lb/min such as the garrett wheeled turbos i.e. AGP RS49=49 lb/min. The other way to rate a compressor's airflow is by CFM such as the Mitsu turbos, i.e. 14b=405 CFM. Those are the only two ways I've ever seen a compressor rated, the g/sec or g/rev would be more applicable for rating the motor, but not the turbo. On a larger motor the same turbo would accelerate up to MAX airflow sooner but still not be able to exceed that MAX airflow. Also Violater, yes, the second part of my reply was directed towards TruWarrior.
no knock1fast97gsx said:my measured airflow is 19.5 ... this is on a scm61 @20 psi and 780 injectors tuned roughly at -40. You can't rely on airflow for anything once you have a few mods.
CanadianTSi said:I'm seeing a little over 22lbs/min I think with the stock SMIC and unported Manifold.
Also I saw 1375hz the other night at the track.
ItsStockOfficer said:Heh, I can more then double your Htz.
