CBgst
- 582
- Jun 25, 2002
I built a leak tester from vfaq. How long is intake supposed to hold pressure. Mine doesn't hold pressure very long at all. The leak is around #2 and #3 injectors. Has anyone ever had this problem before. What do I need to do to fix it. I can't even get pressure above 16psi. Is that why my car is so slow all of the sudden. I just put in a big 28 and at first it pulled like hell at 15psi. After I turned up the boost to 18 psi it pulled hard for about a day and now it sucks. Did turning up the boost cause the leak. If so What can I do to prevent this from happening again. Any help will be greatly appreciated.
