crankbender
- 1,840
- 11
- Apr 15, 2002
houston,
Texas
I wanted to repost this so that people could see it even if they didn't read the dyno posts. I have heard alot of people talking about a bigger turbo making more hp at the same pressure...this isn't exactly correct and I hope this helps show why. You need to get a turbo that does what you want and no more! Don't get a big turbo if you don't need it. You will just hate the lag.
First off i want to set one thing straight that many people seem to be confused on. Your turbo does not have a hp rating. They don't make hp, they flow air. The difference between turbos is how much air they can flow at a certain speed, pressure, and how fast they can turn efficiently. If you want to compare your turbo you have to see what pressure you are at and what temp. When the turbo starts to overspool they add more heat developed through mechanical loss to the intake air. Also they will max out at a certain flow rate.
If you can get a steady pressure at the intake and the same temp it doesn't matter what turbo you are using (except for exhaust back pressure). all of the turbos we use have similar back pressures at reasonable RPMs. Therefore your turbo will compare based on what temp the air at the intake is...get a temp gauge there, it will help you alot.
Don't let people say you have to buy their turbo based on how much hp it is rated for. Ask them for a flow at a certain pressure and what kind of temps it is going to be producing at that flow rate.
Ask them to look at an exhaust housing. How big is the "nozzle" that directs the air onto the wheel? that will dictate how fast you spool (along with moving mass) and what kind of back pressures you will have.
Remember the loss to having a turbo is that when your exhaust valves close you still have alot of used gas in the cylinder because the exhause is usually around twice the pressure of the intake air. that means if you are running 20psi when the exhause valves close you still have the air in the cyl at 40psi and that is used air.....this is why ball bearing turbos are nice they spin easier so require less back pressure.
This may not make alot of sense but basically what i am saying is that if you are looking at a car with a similar exhaust and you have the same engine internals, intake temps, and boost you will make the same hp (roughly) even if your turbos are slightly different. Don't let the turbo companies confuse you bigger turbos do NOT automatically make more hp at the same boost pressures.
. This however is great because the turbo adds heat to the air based on the pressure on it's exhaust to the intake piping not what pressure the engine sees. By decreasing pressure here you are effectively lowering intake temps which lets you get more oxygen to the car even at the same boost pressure! just make sure your fuel is upped slightly to match.
about the off subject but that is cool...send me an icq.
