Skunk Cam Gears
Fredro
Feb 11, 2003
Omaha, Nebraska
I've got a set of super old school Skunk works Racing Project (Skunk2) cam gears and am debating with how to install them properly. I've done enough timing belts to know the tips and tricks, but it seems as if the allignment with these gears is never dead on.
I've found by searching on tons of boards that the marks at one point in time were not accurate, and that they had to be installed the "honda way," which I've never done myself.
Can somebody that has used these much older gears give me a few pointers. If I line up the cam gears with the dowel straight up and down to the motor, the marks appear off on the gears themselves. My gears were also probably tainted by the previuos owner and he etched his own marks on them. If I line up the marks and not so much the dowels with the crank, the dowels no longer look dead on with the head.
Both of these gears are zeroed out and on a set of HKS 272's in case that makes any difference.
since you have 72's, use stock gears and sell those to someone that needs them.
The reason I'm even using them is so that I can bring my idle back up to acceptable terms. Since my block and head have both been milled, I'm figuring that I should be able to make back some of the idle/difference by adjusting the base cam setting.
I basically pull 10 inches of vacuum at idle, and am having other issues because of it.
I'm taking you don't know how to "properly" line these suckers up?
  • For sale 4G63 FIC 1200cc Injectors
    FIC 1200cc Injectors $350 + shipping and paypal fees* injectors were cleaned 6/23/26You must...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
