I need to know if a 16g turbo is better than a T04E
A TO4E what? A TO4E is simply a ompressor cover.(housing) What trim wheels are we talking? What turbine housing? What turbine wheel? I have an AGP l2R. It has a TO4E compressor housing with a 54lb per min wheel. Its mated to a 7cm with a 10 bladed turbine wheel. Its much bigger than a 16G, and capable of much higher HP levels.
I also have a L2R but mine has the smaller B housing. you would have to give a whole run down on the turbo parts before we could tell you. However, generally speaking most turbos using a T04E housing are bigger(not neseccarily better) than a 16G
