fredleysir
- 31
- Oct 14, 2003
Hey guys, I posted this in the General/Newbie forum as it was my first post, but didn't get the response I was looking for. So I thought I'd try it here.
I'm looking to get a 91 Eclipse GSX with the following installed:
-wiseco .020 over pistons on stock (1G) rods
-lightened, knifedged crank
-clevite 77 main + rod bearings
-balancer shafts removed
-BCS restrictor removed
-silencer removed
-hacked air can
-ARP main + head studs
-MLS head gasket
-stage 3 TMO chip eprom
-stock 14b turbo (currently running 11psi)
I want to get as much power out of the 14b as I can. I realize that fuel management upgrades will be in order, but how much could this engine safely boost with stock injectors, pump, and intercooler with the above mentioned internals (remembering that the stage 3 chip eliminates fuel cut)?
I'll probably go with some 550s, 190 fuel pump, and flush out the stock intercooler. What level of boost would I then be able to safely run?
This is my daily driver, and I'd be satisfied with running 12s for an idea on my goals with the car. I'd also like to put in a dual stage boost controller in order to switch between boost levels in the cabin. Forgive me if any of my interests or questions conflict with each other, for I am new to the DSM/turbo scene. Thanks in advance.
-silencer removed
-hacked air can
-MLS head gasket
