69_luv
- 522
- 9
- Nov 3, 2003
Jacksonville,
Florida
Can I use anything to substitute for the gasket between the turbo and header? I have heard some people use thin sheet of copper. Any ideas? I don't want to spend $30 for a "Water Jet Cut 7cm stainless steel turbine inlet gaskets", and most of the other places want $20 plus as well.
Will it hurt/degrade anything by using a cheaper substitute with exhaust gaskets? Going by cheaper methods in other areas is what you pay for, but I am thinking as long as it creats a seal between the turbo and manifold I should be ok.
By the way isn't it really annoying when you buy a turbo/manifold or anything for that matter, that it doesn't include gaskets and bolts, that is unless you choose to by the "2g Install Kit." GRRR at any point.
