Need help choosing Defi gauges
JayB98GST
72
Aug 20, 2002
I plan to get an EGT, Boost, and fuel pressure gauge from Defi. Should I go with the D-gauge series or the Defi-Link series? Also, does anyone know if it is possible to change the LEDs inside the gauges to a different color such as blue in order to make it match my reverse indiglos?
spare the couple of dollar and get the link system.
no you can't chang the led.
look a hell of a lot better than any autometer.
You can be $1000 into gauges pretty easy.
I have the boost gauge only at this time.
i will get the EGT and Fuel pressure very soon.
Get the link.
Only one wire to run per-guage, and they all piggly back, so you only have to run one wire upto your a-pillar-
so for those of you that have defi gauges could you tell me if there are green LEDs that shine through the numbers on the gauge face or if it is lights up the same way that reverse indiglos do? I need to know this cause I just cant have green lights inside my car when everything alse is blue
