Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Tech Article Archives > Articles: Electrical & Wiring
Add to this Article
LinkBack Thread Tools
Old 07-26-2008, 07:47 PM   #1 (permalink)
Proven Member
spoonman's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: spoonman is more helpful than not
1G-specific 1991-1994 ecu swap into a 1990 DSM ignition and ecu wiring
This article presents the procedure for the ignition system wiring changes when swapping a 1991-1994 ecu into a 1990 car with a 90 wiring harness, guages, and coil. This procedure corrects the tach signal so your tach works with a 91-94 ecu. This procedure was covered on the KeyDriver web site which I give full credit for presenting the original wiring schematics. The procedure has been removed from the site and this article is provided to replace it. There is another procedure used for the ecu swap ignition wiring but that way is much longer and requires many more parts.
converting a 1990 to a 1991-1994 ecu system
For this process the only part needed is a power transistor from a 1991-1994 2.0 engine (N/T or Turbo).
The 1990 coil plug has 4 wires coming out of it where as the 1991-1994 only has 3. The color of the wires on the 90 coil plug are as follows from the back of the connector.
1 2
3 4
1=Yellow/Black
2=Yellow/Green
3=White
4=Black/White
Name:  90 coil plug.jpg
Name:  coil wires.jpg
These two pictures show the 1990 coil pack connector and the four wires used.
The 1991-1994 power transistor has 8 slots while the 1990 power transistor only has 6. The wire colors for the 91-94 are as follows from the back side of the PT.
1 2 3 4 5 6 7 8
1=Yellow/Black
2=Yellow/Red
3=Black
4=White
5=No wire
6=Black/White
7=Yellow
8=Yellow/Green
On the left is the 91+ PT and on the right is the 90 PT.
Name:  transitor wires.jpg
Name:  91 power tranistor.jpg
These two pictures show the 91+ PT and its wires.
The 1990 wiring harness is almost identical in the engine ignition area as compared to the 1991-1994. The wires needed from the harness are originally go to the power transistor the colors are as follows.
1=Black
2=Yellow/Red
3=Yellow
4=Yellow/Green
5=Yellow/Black
The first wires that need to be connected are the thick guaged Black/White wires on the power transistor plug and the coil pack plug. The transistor's wire needs to be spliced into the coil plug's matching wire. That is the only wire on the coil pack plug that needs to be changed the rest are untouched.
Then the 1,2,3,7,8 wires on the 1991-1994 power transistor have to be connected to the corresponding colored wires on the 1990 wiring harness.
The next wire that needs to changed is the 4 wire on the power transistor, this wire needs to be lengthened to reach inside of the car so it can connect to the ecu. The wire needs to replace the 109# pin out wire, the ignition pulse detect, the existing wire that was in the 109# spot is to be left unconnected. The 6# and 14# pin out wires on the ecu need to be swapped also. This is a link that shows the pin out location and #'s on the ecu.
1G ECU Pinouts
If you have any questions or comments feel free to PM me at any time. Please remember to rate my tech article.
____________________________
Morgan, bought car for $300.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 07-26-2008, 11:12 PM   #2 (permalink)
DSM Wiseman
steve's Avatar
Region: Midwest
Classifieds Rating: (14)
Since it might help people understand what's going on, allow me to add the functions to the wire colors.
90 Coil Pack
1=Yellow/Black Power Transistor Collector Coil B (2&3)
2=Yellow/Green Power Transistor Collector Coil A (1&4)
3=White Tach Gate output (to noise filter and ECU)
4=Black/White +12v IG1
My references show a different wiring for the 90 Power Transistor Module
1=Yellow/Green Collector 1 (OC1) Coil A
2=Yellow Base 1 (IB1) ECU pin 54
3=Black Ground
4=NC
5=Yellow/Red Base 2 (IB2) ECU pin 55
6=Yellow/Black Collector 2 (OC2) Coil B
And a different wiring for the 91+ Power Transistor Module
1=Yellow/Black Collector 1 (OC1) Coil B
2=Yellow/Red Base 1 (IB1) ECU pin 55
3=Black Ground
4=NC
5=White Tach Gate output ECU pin 109 and Gauge Cluster
6=Black/White +12 IG1
7=Yellow Base 2 (IB2) ECU pin 54
8=Yellow/Green Collector 2 (OC2) Coil A
You'll note that the wire colors match but they switched which of the two transistors was used in the PTM.
The 90 gauge cluster is driven from the output of the noise filter. You need to retain it unless you swap to the later cluster. It should be bolted to the intake manifold somewhere.
The 91+ ECU should now get it's tach signal from pin 5 of the 91+ PTM.
Offline
Old 09-25-2008, 07:17 PM   #3 (permalink)
Proven Member
spoonman's Avatar
Region: Midwest
N/T, The normal (turbo) ecu swap wiring will not work with the 2.0 naturally aspirated engine's wiring harness and a few steps must be changed for the swap to work correctly.
Non turbocharged DSM's use the same ignition system as turbocharged DSM's and the wiring for the power transistor and coil are identical. The difference is that the N/T ecu and wiring harness do not use the (air flow sensor reset) pin which is only used with turbo MAF sensors and connects to the ecu at pin 14 on 1990 ecu's and pin 6 on 1991-1994 ecu's. To correct this you must remove the 6 wire from the ecu harness connector and insert it into the 14 slot of the connector. If you do not switch the wires your car will have trouble deciding if you are in decel mode and will make your engine stutter at low RPM decel.
Offline
Old 09-25-2008, 08:36 PM   #4 (permalink)
DSM Wiseman
steve's Avatar
Region: Midwest
Quote:
Originally Posted by spoonman View Post
The difference is that the N/T ecu did not change its wiring pinouts after 1990 like the turbo ecu, so the 6 and 14 pinouts on the ecu do not have to be switched.
I don't think so. Just like with the turbo ECUs the IPS switched location between the 90 and the 91+ ECUs based on every one I've looked it. So yes, you don't swap 6 and 14 but you do swap pin 6 to 14 on an NT car when mixing 90 and 91+ cars and ECUs.
You may also notice that the N/T wiring harness and ecu do not use the 14 pinout as it is for an extra wire (idle switch) on the turbo MAF sensor that the N/T does not use.
It's the MAF reset signal (Green/White) that the NT ECUs don't have/use. That's what was on pin 14 on the 90 ECUs not the IPS. The IPS (Green) is a key input for managing idle speed, dashpot control, and deceleration fuel cut on both the NT and turbo ECUS. It's on pin 6 of a 90 ECU and pin 14 on the later versions.
Offline
Add to this Article
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are Off
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cylinder head turbo 2.0 1990-1994 eclipse talon DSM 1G - DSM eBay Auction Admin eBay Auction Links 0 06-03-2008 09:30 PM
1990 ECU in a 1991 Skillz Problem Diagnosis 25 01-20-2005 10:14 PM
1990 ECU in a 1991 lovetheturbo Tuning & Engine Management 2 05-17-2004 01:26 PM
1991-1994 in a 1990 streetraceboi Bolt-on Tech 4 01-17-2003 12:54 PM
Page generated in 0.16243911 seconds (77.90% PHP - 22.10% MySQL) with 11 queries
