coolant pipe diameter for water temp gauge fitting
sechen77
37
Dec 28, 2003
bay area, California
anyone know the coolant pipe diameter for 1g? i am interested in using a AC autotechnic fitting for the water temp sensor, but they come in 1", 1 3/8", 1 3/16", not sure which one i should get, and does anyone know if they would fit the autometer sensor? thanx
you should just be able to put a sensor in the thermastat housing were it belongs. Id imagin you have some extra stuff in it that can be removed ?
You have lost me somewhere - to me the Coolant Pipe is that big pipe that runs across the front of the motor to the Water Pump... Do you mean Thermostat Outer Diameter? Where does this thing go? Gotta link to the product? You can't really screw with the Engine Temp Sensor at the Thermo Housing because that talks to the ECU - The perfectly good Stock Water Temp Gauge Sensor is also at the Thermo Housing - the Fan Thermo Switch at bottom of Radiator...
oops, i meant the coolant rubber hose from the T housing to the radiator, what's the ID of the rubber hose?
