Stock alarm for eclipse Question...
WhiteCharisma
273
Jul 7, 2003
Hialeah,
Hey guys is there a way to djust the sensibility of the stock alarm system on a GS-T:confused: if so how can it be done... thanks in advance....
i wanna bring sensibility down quite a bit,now i just tap the hood and that thing goes off...i even think strong wind sets it off,ive had to get up in the night to go turn it off,its buggin allready...
I don't think that's a stock alarm. Mine only goes off is doors are opened etc... No touch sensitivity.
I don't know if my alarm is stock or not, but my sensitivity switch is behind the driver's side kick panel by the ECU. Check there if you haven't yet.
My alarm is definately stock,when i lock my car with the key a green light goes on in the gauge cluster that says SECURITY..^^^ ill check there,what does the switch thing look like dude??...
Alright, I don't know if this will help or not, but the alarm trigger under the hood is just like a switch covered in black rubber and when the hood is closed, it pushes down on the top of the switch. You can move this switch around (change the angle), to make it have better contact w/ the hood. That should help with the sensitivity problems. Sorry this is very vague. Shoot me a pm if you have any questions.
he's got the stock alarm... mine goes off with hood, trunk and doors. well it used to with the doors, but my switches need to be cleaned [again]
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
