Best place to send Valve Cover to be powdercoated stock 95 talon blue?
i would take it to a body shop to get the identical color. i am sure they can add a heat additive to the paint so it wont chip off. you might get lucky and find a body shop that powdercoats.
Theres a place a couple hours north of me that does automotive powerdoating, although i dont know if they do individual oders.. you might need a batch for them....
Do a search for CRM in traverse city michigan.
Or if you have a cheap ass oven that can bake around 400* you can do it yourself.
A valve cover doesn't get hot enough to warrant powdercoating, other than how popular it is these days. A thorough cleanup and prep, and you could use Dupli-Color or any other factory-matched spray enamel.
The reason I want the powdercoating is because carb-cleaner etc wont take the finish off.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
