Anyone that has painted there dash!
97GSXEclipseBoy
Sep 24, 2003
This is to anyone who has painted there dash. I wanted to go White dash on my 97 GSX. Anyone else have a white withpics or have seen how it looks or any advice about painting a dash.
well, at first i did my dash in white. it is very time consuming, you have to be able to have the time to let your car sit due to the fact you need to take the dash out. now with white, it look awesome if you do a good job. problem being though, you have to clean it every couple days cause it gets dirty very quickly. i just redid my dash to black and chrome. the paint i used was krylon. my suggestion if you do it is, be sure to take everything out of your car. wash it all, then sand it. give it a couple coats of primer, then a couple coats of paint. let it sit and dry for around 2 days. then after that, clear coat it. that should do the trick. if you have any question, IM at dewman0012.
