RobStaff
- Apr 17, 2003
Will a stock 1g CD player play burned CD's??
Thanks
Thanks
...Defiant said:I've had better luck with slower burn speed.
The dealer should have supplied one. They're readily available, for about $3.tstkl said:is there a harness adapter you can buy to go from one to the other,
Factory amp and rear CD changer cables.or was all my time not wasted.... and also there was a third harness that i didnt use at all, and a (what looked like but i know isnt) power supply cored thats thick and L shaped at the end, it went into the radio, then one went from the radio to the cd player, but it isnt used anymore, along with that third harness, what did they do?
damnit.... thats cheap...Defiant said:The dealer should have supplied one. They're readily available, for about $3.
k i dont have a rear cd changer, but im assuming that i can either A) remove the factory amp to save weight, or B) use the factory ampDefiant said:Factory amp and rear CD changer cables.
