Help- 92 drift front fascia on 90
16GTSI
148
May 9, 2003
Metamora, Michigan
Ok i ordered the 92-94 drift kit for my 90. I have been informed a little fiberglass work makes the fascia work on the 90 cars which i agree with. The problem is the kit doesnt fit over top of the front beam. The is no way i am going to install the front fascia without that front beam so whatdo you do? Do you just have to hack the hell out of it and weld it back up, or is there a trick i havent learned? Anybody out there that has done this installation please help me out.
mine is a 92, but we had the same problem and in the end, we had to remove the support because it wasnt worth the time it would take to grind it down in the right spots. we fabricated a new support and welded it on. you cant tell at all, but i do hope that i dont get in a bad front end wreck because im sure its not as strong as stock
