I need some input...
jrider
121
Mar 31, 2003
Detroit, Michigan
I have a Sidewinder 6500 ESP alarm/remote start system in my car. This alarm is made by DEI, who also makes the Viper, Hornet, Python, etc. Has anyone ever started having a problem with their transmitters? I've changed the battery in each, and the LED's on the remotes light up bright so I know it's not the battery. The range on them both is really quite poor now; and they don't seem to work real stable (I have to push the button a couple times in order for it to work). One of the remotes has to be held right up to the windshield in order for it to work. Before I go Ebaying for new remotes I want to make sure that is what it is exactly. If anyone has any knowledge what-so-ever of DEI's (Directed Electronics www.directed.com) systems, or has every experienced transmitter problems, please let me know. Thanks.
By the way, I have checked the antenna wire. It is secure. I reprogrammed the remotes and now each one only works if I hold it right up to the glass where the antenna is mounted. If I hold it near the actual unit under the dash, I get nothing... so anyone?
  • Wanted 1g Wanted - 91-94 1g Throttle Body or replacement shaft + plate
    Looking to replace a TB with a complete 91-94 or replace TB shaft + plate. Let me know!
    • athlete3344
  • For sale 1g 90 Oil Cooler
