jdmawd
Banned Member
- 3,318
- Mar 20, 2002
GreenBelt,
As you can imagine the stock speakers in my 92 are garbage. I picked this head unit up and would like some input on the best quality speakers to accommodate this head unit.
here are the specs
Direct Track Access
- 1-bit DAC
- CD Player Random and Repeat Play mode
- Direct Disc Select (1-12)
- CD Changer modes:2 Random Play, 2 Repeat Play modes
- HS-II Tuner. European Switchable Tuner.
- 18FM+6AM Presets
- SSM (for FM)
- AFNS/PNC
- Tuner Scan
- Spectrum Analyzer, Level Meter, Multi-Color LCD Display, CLD Back Light, Switchable Dimmer, Power Switch Standby Illumination
- Remote Control
- Sound Control Memory
- COMPU PLAY
- Power-Off Mode Eject, Preferred Setting Mode 40 W x 4 Max. Power Output
- Electronic Volume Control
- Loudness Control
- Bass/Treble/Balance Controls, Volume Attenuator
- Line Out Terminal (1 pairs/gold)
- Preamp Fader Control
- Front AUX Input (Gold)
- Tape Auto-Reverse
- Tape Full Logic Mechanism
- Grooved EHP Tape Head
- Dolby B NR
- Metal Tape Compatible
- Multi Music Scan
- Repeat
- Key-Off Release / Key-On Play
here are the specs
Direct Track Access
- 1-bit DAC
- 18FM+6AM Presets
- SSM (for FM)
- AFNS/PNC
- Tuner Scan
- Remote Control
- COMPU PLAY
- Loudness Control
- Tape Auto-Reverse
- Dolby B NR
- Multi Music Scan
- Repeat
pioneer and kenwood would suit u well... just to let u know u cant get deep 6x9's for the rear unless u get em custom installed.. if u want to find out what will slide right in go to
.. i tryed to cram my kicker 6x9 3 ways in there myself and it was a no go... if u want a bangin system ur best bet would be go talk to a shop around ur town they helped me plan my system out
