DSMhelex
- 445
- 2
- Jan 8, 2003
Du Bois,
Pennsylvania
im trying to build a competition system, and wondering what is the loudest in 2g dsms? ported, sealed, or bandpass.... i have a sealed in now, and its okay, but i ran a single 12 bandpass and it was pretty loud... i'd like to know if any of you have experimented with different types of boxes in your eclipse/talon....
i guess is that bandpasses work for our cars, because of the hatchback, they dont always work for all cars. ive looked at two different bandpasses..... two 12's which hold 400w rms, and two 15's that hold 1000rms
if i go with the 12's, i can run an 800w amplifier
if i go with the 15's, i can only run about 500w - 600w amp
im trying to stay in the middle competition classes, using hte IASCA classes. i dont want to be competing with a guy whos got 5 subs and two rf 2400w amps...
which box do you think is the loudest, and if bandpass, which do you think i should go for?
any input at all would be most helpful
Jerred
Jerred
but if you are wanting spl do not use sealed; and about bandpass, you prolly don't have enough room to have a proper size enclosure. (most prefab bandpass boxes are way too small and aren't good at all) I suggest you run the biggest ported box you can w/ the sub facing up towards the hatch and the ports facing backwards. If you would like for me to help you with the design pm me and i can help ya out.
Hey i have a sealed box in my trunk and i think performance wise is as good as it gets, considering that i made the box myself and it sounds better than any prefab box i ever had, what id like to do is fabricate a fiberglass face to give it a competition look, any suggestions?
