FOund good wiring diagram on DSMtalk.com
RedEclipseGS
265
Jan 9, 2003
:D finally i found a good diagram for speakers or anything you want to wire...this may be a repost but i couldnt find it in the search. This was posted on DSMtalk.com:dsm: :thumb:
2G DSM Wiring (eclipse, should match Talons) (post #21)
<b>Security Information</b>
Constant 12V+ White Ignition Switch Harness
Starter Black/Red Ignition Switch Harness
Ignition Black/White Ignition Switch Harness
Ignition 2 Blue Ignition Switch Harness
Accessory Blue/Black Ignition Switch Harness
Tach Black/Blue Or Blue/Black Coil Pack (2 Cylinder Setting)
Neutral Safety Wire Black/White (-) PCM behind Center Console
Brake Switch Green Brake Switch
Trunk Pin Red/Green Silver Driver's Kick Panel
Parking Lights Green/White (+) Driver's Kick Panel or Fuse Panel
Head Lamp Red (-) Light Switch
Factory Disarm Green/White (-) Driver's Kick Panel
Door Trigger Red/Green (-) Courtesy Light or Driver's Kick Panel
Door Lock Brown/White (-) Behind Fuse Panel or 20 Pin Connector High Driver's Kick Panel
Door Unlock Brown (-)
Driver's Lock Blue/Black Driver's Kick Panel
Driver's Unlock Blue/Red Driver's Kick Panel
Passenger Unlock Blue/Red Passenger's Kick Panel
Horn Wire Green/Red (-) Steering Column
Windows Up LF=Green/Red, RF=Brown/Yellow
Windows Down LF=Green/Black, RF=Green/Yellow
<b>Cruise Information</b>
Constant 12V+ White Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Black/White Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a Brake Switch
Cold Side of Brake Green Brake Switch
VSS Lead Yellow/White Driver's Side of Console
Pulses Per Mile 4000 PPM
<b>Stereo Information</b>
Constant 12V+ Red/Black
Switched 12V+ Blue
Ground Chassis
Illumination Green/White
Dimmer Black/Yellow
Antenna Trigger White/Black
Antenna Left Rear
Front Speakers 5 1/4" Doors
Left Front (+) Black/White
Left Front (-) Black
Right Front (+) Black/White
Right Front (-) Black
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
:dsm: :talon:
