Turn signal/sidemarker bulbs
A. Van
346
Jul 1, 2002
Are the turnsignal and sidemarker clear or amber? I'm going to be clearing out my headlights and getting clear sidemarkers and want to use amber bulbs, to remain legal. Also, if there clear does sylvania(sp) make amber bulbs that will work in there place?
Thanks
I believe sylvania makes replacement bulbs in yellow. Call the kragen or autozone near you to check. Good luck...
I went to the store and found the same serial number as the clear but in amber. I think it's 1157na(amber) for sylvania bulbs.
Are the sidemarker bulbs the same as the turnsignal bulbs?
On 1ga's the corner isnt the one that blinks when you put your turn signal on so you can keep a clear bulb in the clear corner.
