I Need Help!!!!!
UCSammy
66
Jun 21, 2002
Well after my swap, my turn signals, brake lights, and hazards dont work. I checked all the fuses, so I am lost. Im sure its something easy, but can anyone help?
did you have to get a new harness or anything....if so they might have messed somethign up..
The only harness I replaced was the motor harness.
I was thinking it was a flasher fuse or relay but I have no idea.
yeah check your relays in the bay and under the dash....ummm did you check all your connection on the plugs..make sure they aren't corroded or anything...
Well I checked all links, relay, and fuses. Anyone have any ideas?
