Psycron
- 217
- 1
- Jul 29, 2002
Farmington Hills,
Michigan
Check this link out, it's the PDF for a standard, professional install including the tools required and connector diagrams. Work your time if you're doing an install.
http://www.installdr.com/InstallDocs/Mitsubishi/PDF/648005.pdf
Any suggestions on how to route the rca cables and speaker wires from the center console would be appreciated, I'm deciding placement of the amp and the best way to get the wires back there. Would a thicker gauge wire be recommended? Should I disconnect the stock wires from all the speakers then bind/tie the wires down so they can be attached if need be? They're going to be running into the stock harness but since I won't need it I can re-route them to amp wherever I put it and run RCA cables from the HU back to the amp.
All that is left from there is to connect the remaining wires from the harness on the HU to the stock harness and ignition. I should be good to go! Does this sound like a professional install? I'm missing the stock mounting brackets since the last owner took his single DIN stereo out along with the mounting brackets...just have to order one from conicelli mitsu. Thoughts?
